POWERSTAR PS200-12-8 12V 200AH SOLAR POWER BATTERY DEEP CYCLE 2 YEAR WARRANTY 4D SIZE
Features- Replacement FNC 122000 Sealed Battery Fully Rechargeable AGM
- Voltage - 12V
- Capacity - 200Ah
- PowerStar battery general Sealed Construction PowerStars's unique construction and sealing technique ensure that no electrolyte leakage can occur from the terminals or case of any PowerStar battery.
- This insures safe efficient operation of PowerStar's batteries in any position.
- Absorptive Glass Mat System (AGM System) PowerStar batteries make use of fine mat separators (glass fiber) wherein suffient electrolyte is absorbed to provide the longest life and steady serive.
- This system prevents escape of electrolyte from the separator which causes leakage.
- Gas Recombination PowerStar batteries incorporated unique design that effectively controls generation of gas and allows recombination of over 90% of gas generated during the normal use.
- 200ah Solar Power Battery Deep Cycle 4D Size
- 2 Year Warranty
- Dimensions - 20.5 x 8.58 x 9.37 in.
- Item Weight - 135 lbs.
Price: 1534.42
