ATD TOOLS ATD-5493 WIRELESS BATTERY SYSTEM DIAGNOSTIC TESTER
Wireless Battery & Electrical System Analyzer.
Features- This Wireless Battery System tester allows the user to run battery starter and charging tests from inside the vehicle or while the vehicle is driving.
- Tests all 6V 12V & 24V lead acid batteries individually or in parallel and series battery packs.
- The wireless tester is also ideal for testing hard to reach batteries and battery systems in trucks and marine applications.
- With remote distances up to 50 feet shop owners can show customers in the waiting room real test time data on the display.
- Battery Size Range: 100 to 3500 CCA (Parallel > 1700 CCA)
- Battery Voltage Range: 6V 12V & 24V Batteries
- International Units Displayed: EN EIC UIN Ah JIS
- LCD Display: 2 line 16 character
- Transmission Frequency: 900MHz
- Item Weight - 3 lbs.
Price: 558.87
