The SCL8/15 Solar LED Courtyard Light is completely self contained and does not require an electrician to install. After installation there are no electric bills or maintenace required other than keeping the Solar Panel clean. The LED Solar Light consists of a high efficiency solar panel charge controller infrared sensor high-capacity lithium battery and LED module assembled into a compact weatherproof housing. Hundreds of dollars in installation costs are saved since no hook up to the power company is required and an electrician is not required. Just mount the Solar LED courtyard light to any flat surface or 3 pole fence tree branch or building making sure the solar panel has full exposure to the sun and its ready to go. No special tools required. The adjustable mount allows for maximum charging by adjusting the angle of the solar panel for optimum sun light exposure.
Features
